Hydraulic clutch line.
JIM 1944
  • CHEVROLET S-10
1996 gmc sonoma sl 205 kilometers 2.2 motor 5 speed trans. 2 wheel drive. I am replacing the clutch assembly. How do you release the line from the inside of bell housing? My Haynes book said to push the white plastic down with 2 small screw drivers and pull out the connector. I pushed the white plastic collar down and it still won't release. It is down level with the brass body. Does it have to go further inside to release? My 92 Ford Ranger had a similar set up, but it popped off easily when I pushed the plastic down.
Monday, November 19th, 2007 AT 1:01 AM
TOBYU
  • 89 POSTS
Try pushihg the line itself in as far as it will go before pushing the retaining ring in.
Monday, November 19th, 2007 AT 1:18 AM
JIM 1944
I got the line apart. Turns out just pushing the white plastic sleeve in and pulling on the plastic clutch line and wiggiling it a few times worked, it just popped apart. Thanks for the reply. Jim
Sunday, November 25th, 2007 AT 11:21 AM
