1997 Chevrolet S-10 No Fuel Pump Power
LOVEBIRD
my truck is a 97 s10 4.3 vortec 2 wheel drive mileage is 147,000 has 2 replace fuel pump now there no power to the pump
Jul 14, 2007 at 4:15 PM
PROBLEMS33
i have the same problem but in a 94 please send help, Bruce
Jul 29, 2007 at 4:07 AM
  • 55,746 POSTS
You need to replace the fuel pump relay, also check the connector right at the pump, hi resistance could cause the connector to over heat and short circuit. The fuel pump relay is located under the hood near the fire wall. for exact location you need to follow this link. https://www.2carpros.com/kpages/auto_repair_manuals.htm ...plus you must use a AC Delco pump. Any after market pump is inferior. :D thanks for visiting 2carpros.com
Jul 29, 2007 at 4:18 AM
PROBLEMS33
i have really checked all that , i have even run pump hot and the truck wont stay running so i think these two problems are linked together
Jul 29, 2007 at 4:25 AM
  • 55,746 POSTS
does it have fuel pressure when it stalls?
Jul 29, 2007 at 4:48 AM
PROBLEMS33
the only way it runs is if i feed it. but yes it does have pressure. but also when you turn key on , no power to the pump, so i hot wired the pump to get the thing home. but still no run.
Jul 29, 2007 at 8:36 AM
Suggested Repair
Replace the fuel pump relay under the hood near the firewall, and inspect the connector at the pump for high resistance, overheating, or a short. Use an AC Delco fuel pump rather than an aftermarket unit.
Conversation Summary
A 1997 Chevrolet S-10 4.3 with 147,000 miles had no power to the fuel pump after two pump replacements. An expert advised replacing the fuel pump relay, checking the pump connector for high resistance that could overheat and short, and installing an AC Delco pump. A second owner with a 1994 reported the same issue, said the checks were already done, and noted that the truck only ran when fuel was fed to it despite having pressure and a hot-wired pump. The expert asked whether fuel pressure was present when it stalled, but the thread ended without a confirmed fix.
