i have a 01 s10 with a 2.2 4 cly. the fuel pumped stopped working (the truck ran fine the day before) i spent 390 .00 on a new one thinking the pump was bad after replacing the old plump the new pump still does not work the truck only hsas 51 k on it i have spark at the plugs, the engine cranks fine but still fuel is reaching the injectors. no humming at the pump i checked the filter also but no fuel there either yes there is gas in the tank could the relay go bad in the fuse box? im at a total loss
Apr 11, 2007 at 11:43 AM
