fuel delivery problem
CARTERRA3
1995 S-10 zr2, 4.3 litre cpi motor. went to start it leaving work yesterday, it ran about 30 seconds, then died as though i had turned the key off, and now it wil not start back up. i replaced the fuel filter, and today i take the line off the filter and turned the key on, of course gas went every where, so the pump is providing enough pressure to where it at least ought to sputter, but it just cranks and cranks without catching... help?
edit: it is getting spark, we checked that...
Oct 31, 2007 at 9:46 AM
BLACKOP555
  • 10,386 POSTS
try some starting fluid to see if it starts up. Check fuel pressure at the fuel pressure at the fuel rail also and listen to see if the fuel injectors click when the key is turned and engine is being cranked. if so clean the injectors if not check for voltage at the injectors.
Oct 31, 2007 at 12:06 PM
