anti lock brake problem
WILDMANS99
I have a 1995 chevy S10 blazer 4x4 auto. Changed the front brakes and rotors and now the abs light on dash is on and abs isnt working. do you have to reset this, if so how or is it something else.
Oct 23, 2007 at 5:43 PM
SERVICE WRITER
  • 9,123 POSTS
Pull the whels back off, make sure the abs connector is still tight, check the sensor to make sure there are no metal shaving and is clean. Make sure the abs ring is not cracked or has anything in it.
You can narrow down the wheel by pulling the codes from the computer. IT may be ironic timing that the light came on and may be a different source.
Oct 23, 2007 at 10:17 PM
