1994 Chevrolet S-10 Locked Rear Brake
Suggested Repair
Do not rely on the seller's diagnosis. Retract the rear drum brake adjusters fully, tap the drum with a hammer to free it, and remove it. Then raise the rear and check whether the wheels turn. If they do not, the rear axle or driveline may be locked rather than just the brakes. Have a professional inspect the truck before buying.
Conversation Summary
A buyer considering a 1994 S-10 was told the rear brake was locked and that towing did not free it. Experts warned the problem could instead be the rear end or driveline and advised verifying it before purchase. Suggested checks were retracting the adjusters, freeing and removing the drum, then raising the rear to see if the wheels turn. If they still will not turn, the rear end is likely locked and the buyer should look elsewhere.
