1995 Chevy S-10 Blazer ABS Light On
WILDMANS99
I have a 1995 chevy S10 blazer 4x4 auto. Changed the front brakes and rotors and now the abs light on dash is on and abs isnt working. do you have to reset this, if so how or is it something else.
Oct 23, 2007 at 5:43 PM
SERVICE WRITER
  • 9,123 POSTS
Pull the whels back off, make sure the abs connector is still tight, check the sensor to make sure there are no metal shaving and is clean. Make sure the abs ring is not cracked or has anything in it.
You can narrow down the wheel by pulling the codes from the computer. IT may be ironic timing that the light came on and may be a different source.
Oct 23, 2007 at 10:17 PM
Suggested Repair
Recheck the ABS sensor connectors for a tight fit, clean the sensors of metal shavings, and inspect the ABS tone rings for cracks or debris. Pull ABS codes to identify the affected wheel; the light may also have an unrelated cause.
Conversation Summary
The owner of a 1995 Chevrolet S-10 Blazer 4x4 says the ABS light came on and ABS stopped working after the front brakes and rotors were replaced, and asks whether a reset is required. The expert advises checking connector tightness, sensor cleanliness, and the ABS ring, and pulling codes to narrow down the wheel, noting the timing may be coincidental.
