My ac on my chevy S10 1996 only blows out of the defrost nothing out of the vents any idea.
Oct 17, 2007 at 8:06 AM
Inspect the vacuum feed to the dash. Check the small black plastic line under the hood that passes through the firewall, confirm it is connected to a vacuum source, and verify the check valve on that line at the rear of the upper intake.
The owner of a 1996 Chevrolet S-10 reports that the air conditioning only blows from the defrost outlets and not the vents. The expert says vacuum feed to the dash has been lost and advises checking the small black plastic line through the firewall, its connection to a vacuum source, and the check valve at the rear of the upper intake.
