I have a 1999 chev S10 4 cyl truck. When I run the A/C, the floor gets soaked on the passg. side.
What could be doing this?
Jul 9, 2006 at 1:50 AM
Check the evaporator drain under the truck for a clog, and inspect the drain tube and ducting for a leak that lets condensate soak the passenger floor.
The owner of a 1999 Chevrolet S10 says the passenger floor gets soaked when the A/C runs. The expert assumes it is water and attributes it to a clogged or leaking evaporator drain, recommending that the drain under the truck be cleared and the ducting opened to find the clog or leak.
