I have the truck listed above with a 4.3 engine and 144,000 miles. It started out when I am driving it will act just like it wants to downshift, mechanic replaced the fuel filter. Next problem when you start out it acts like it doesn't want to shift at all, when and if it finally does shift, it jerks really hard through the first 3 shifts. Mechanic replaced the TPS sensor, MAP and O2 Sensor also did a transmission flush. Now it's still shifting hard at times the light came on came back to a TPS code have replaced it again but still have the same problem. Also while I am driving it it acts just like I have taken my foot off the gas pedal. My mechanic doesn't know, he had a trans guy look at it and he said the transmission is fine. So this has been going on for a year and 3 mechanics later nobody knows what it is. Any thoughts?
Oct 31, 2007 at 3:27 AM
