Engine idles fine but no power on acceleration?
1995 CHEVROLET S-10
LOU P
  • CERTIFIED EXPERT
  • 118 POSTS
Does it matter if the engine is hot or cold? does it run differently?
Dec 14, 2020 at 9:24 AM (Merged)
WESWALKER88
  • 15 POSTS
No it does not. I order a temperature sensor i just read that could cause this problem with Chevrolet's.
WESWALKER88
  • 15 POSTS
Hot or cold runs the same.
LOU P
  • CERTIFIED EXPERT
  • 118 POSTS
this is a good one. have you verified battery voltage at low and high rpm and at the engine control unit?
i think you said you did the timing. do you have a scan tool that can read live data while the engine is running?
WESWALKER88
  • 15 POSTS
No, I do not have a scam tool, but I replaced the ECU.
WESWALKER88
  • 15 POSTS
Evap leak? Any idea where I can get a diagram with the accumulator on it I have been searching the web and cannot find one.
  • CERTIFIED EXPERT
  • 53,902 POSTS
Hey WESWALKER88,
I am starting to think you may have a broken valve spring. can you remove the valve cover and check each spring with a flash light please? Also, while you have the valve cover off check the camshaft lift while cranking the engine over see if one of the rockers is not moving as much. Disconnect the coils so the engine does not start.
Best, Ken
WESWALKER88
  • 15 POSTS
Checked all good
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
there is a solenoid on evap not actuator it by the fuel tank.
WESWALKER88
  • 15 POSTS
Know what it's called our how to check it
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
yes you ground one side and put power to other if it clicks it works if not it doesn't pretty simple you haven't done anything anyone has replied to your questions
