94 S-10 shuts down at 210 degrees
ABRAMSARAI
  • 1994 CHEVROLET S-10
I have a 1994 S10 w/107,000 mi. V6 Vortec motor, auto trans. Have started to experience a very strange thing. Any time the engine temp goes to or even gets near 210 degrees, the motor shuts down. I thought it was an overheating problem, so I flushed out the cooling system, was a mess, but that part of it is now fine. Still happened. Removed the T stat (I live in Vegas, very hot here, this is a very common thing to do here). It takes longer for the engine temp to reach 210, but if it does, it still simply shuts down. I also replaced the coil, thinking that it may have aged and become faulty, nope, that didn't do it either. Even if the truck has been running ok, and you stop to run in to a store or something, if the temp gauge goes up to 210 degrees (sitting w/o running) it will not start untill after sitting for about an hour to "cool" down. Someone told me that the auto choke/shutdown relay might be going bad, but I have not a clue as to it's location, it is not covered in any of the common manuals, I know, I have enough of them. Signed, Very Frustrated!
Thursday, August 9th, 2007 AT 1:37 AM
MERLIN2021
  • 17,250 POSTS
Thats strange considering the thermostat doesn't fully open til it get to 206! Try replacing the temp sensor.
Monday, August 13th, 2007 AT 2:12 AM
