My S 10 will start for about 15 seconds. I have check the fuel pump, 9 psi. I have checked the fuel filter and it is fine.
Saturday, December 29th, 2007 AT 8:39 AM
MECHANIC
Check engine light is it On or has flashed?
Check the coolant temperature sensor, idle air control valve, throttle position sensor and EGR-
SPONSORED LINKS
Saturday, December 29th, 2007 AT 12:32 PM
GTOWNKAYLEE
MEMBER
I don't know if the 93's had passlock, but if it does check the fuses on the fender well under the hood. I had a 98 do the same thing and it was the fuse.
