The Engine stalls, hesitates and runs rough when first started and cold. After it warms up it runs fine
Monday, December 17th, 2007 AT 9:55 AM
MERLIN2021
MECHANIC
Try testing the ect(electronic coolant temperture) sensor. With an ohm meter the ohms should change as the engine warms, it also acts like a choke for TBI.
SPONSORED LINKS
Monday, December 17th, 2007 AT 1:16 PM
2JUSTIN0
MEMBER
Check the pre heater house located on the driver side. Its a flexible hose located on the manifold and goes into the air intake, it acts as a choke and its sole purpose is cold weather starting, mine comes off every so often and my truck will do the same thing.
