1992 Chevy S-10 Rear End Fluid Fill Fix
JACOBOSNESS
1992 s10 pickup. 210,000 miles, standard, 4.3L. my question is how to fill the rear end with fluid after taking off the cover?
Sep 23, 2007 at 12:20 PM
BOOTDOG
  • 665 POSTS
you have to clean off the old gasket and reseal it with black RTV silicone. in front of the differential is a fill plug you can remove with a 3/8 drive ratchet. fill it with 90w gear oil till fluid runs out and your done.
Sep 26, 2007 at 3:44 AM
Suggested Repair
Clean the old gasket material and reseal the cover with black RTV silicone. Remove the fill plug in front of the differential with a 3/8-inch drive ratchet, then add 90W gear oil until fluid runs out of the fill hole.
Conversation Summary
The owner of a 1992 Chevrolet S-10 with a 4.3L engine asked how to refill the rear differential after removing the cover. The expert advised cleaning the old gasket, resealing the cover with black RTV silicone, and filling 90W gear oil through the front fill plug until it runs out.
