1994 chevy s10 pickup
MATTABRAMS
i have a 94 s10 pick up,v6 4.3 liter ohv,automatic 2 wheel drive, and it never starts unless i use starter fluid,if not, and try with out the starter fluid it wont start,the engine turns,but it doesn't catch,and eventually the battery dies!...can it be a problem with my charging system? should i have autozone test it?...i had a mechanic test the fuel pressure and spark,and fuel pump,it's getting gas,all checked out perfect!....PLEASE HELP
Mar 21, 2007 at 10:55 AM
SERVICE WRITER
  • 9,123 POSTS
Just to clarify, It will NEVER start, unless you use starting fluid, whether the engine is hot or cold.
This is not charging related.
Mar 21, 2007 at 11:22 AM
MATTABRAMS
what would cause it to need starter fluid to start? and when ever it is started and i drive it, usually it will start up fine after running around town
Mar 21, 2007 at 12:00 PM
SERVICE WRITER
  • 9,123 POSTS
OK, so it will start when it's hot.
Your having a bleed down problem.
The starter fluid is giving the engine instant fuel, and that is why it will start when it's cold with the fluid.
You have one of two likley scenarios.
1- Fuel pump check valve is bad, therefore a pump is needed.
OR-
2-There is a "open area" in the fuel injection "spider"
Wither one is fairly common on those. What happens as the truck sets, the fuel line becomes "de-energized" as the fuel is allowed to return into the tank, which is not normal, the fuel should remain there. When your turn the key on the fuel pump add more pressure to a line that it expects to be full of fuel already and doing what the starting fluid is doing for you. That is instant fuel to the motor.
When you run around town, the fuel line hasn't had a chance to bleed down in the short period.
Mar 21, 2007 at 10:03 PM
