Oil sending unit?
BRYANPITTMAN
Well the only other sensor is for an s10 that has a z or w in like the 7th spot of the vin number of the truck and my vin number doesnt have a z or w in it at all.
Wednesday, August 28th, 2019 AT 9:35 PM (Merged)
DEWAYNE GRUBAUGH
  • 1993 CHEVROLET S-10
Electrical problem
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 112k miles
fuel pump quit, or so I thought. Aftter replacing fuel pump and before reinstalling gas tank, I applied 12 volts to pump and heard it run. Then I checked again after I plugged the electrical connection together under the truck and turned on the ign but pump did not run. I unplugged connection and I do not have 12vdc at the plug. Fuse is good. I believe the fuse is labeled ECMB. I looked at a wiring diagram in a repair manuel and it said to check the fuel pump relay and the oil pressure switch. I cannot find either. Where are they located and what do they look like? Are we talking about the oil pressure sending unit that works the oil pressure gauge or lite:
All you got is 2secs to look for power at the gray wire anything over 2 sec you ain't gonna have it the fuel pump relay de-energizes which is controlled by the computer-When the engine fires up the oil pressure sending unit powers the pump see below-
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_34.gif
WRENCHTECH
  • 20,761 POSTS
That would be because both of those choices are for the 4.3 engine options and you have the 2.8
BRYANPITTMAN
Well then there is only one sensor for my truck and thats the one I got.
AALAMO17
What would happen if after 10 minutes of being on one turned it off and the fuel pump remains activated.
WRENCHTECH
  • 20,761 POSTS
If unplugging it sender stops the fuel pump, then the sender is the problem.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Unfortunately, you've attached a response to a years old question.You need to start a new question with the symptoms and your vehicle . Here's the link:
https://www.2carpros.com/questions/newinformation.
Thanks for using 2CarPros.
Danny-
SISKO89
  • 6 POSTS
  • 1992 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 141,000 MILES
The oil pressure gage keeps jumping while engine is idleing. Gage smooths out when rpms increase.
Do I need to change the oil pressure sending unit.
  • 31,937 POSTS
Hi there,
Just to be on the safe side, have the engine oil pressure tested with a master gauge, this will give a true indication as to the oil pressure. If all OK change the sender.
Mark (mhpautos)
MATT4401
  • 12 POSTS
  • 1991 CHEVROLET S-10
Electrical problem
1991 Chevy S-10 4 cyl Two Wheel Drive Manual
Where is the water temp sensor and the oil pressure sensor located on the engine? The engine is a 2.5L 4 cylinder in a 91 chevy s10.
2.5L VIN E oil pressure switch located at oil filter flange
2.5L Coolant Temperature Sensor On thermostat housing
MATT4401
  • 12 POSTS
Ok cool, I see the coolant temp sensor, but not the oil pressure switch. There is a sensor on the back of the head with one green wire coming out of it. What is that sensor for?
Oil pressure switch is at the oi filter flange
MATT4401
  • 12 POSTS
Does it have 2 tan wires and an orange wire coming out of it?
This wires is it coming out of a connector threaded in the engine on the flange of the oil filter-the colors I got is gray and orange.
Is this a blazer or truck?
RERAIL
  • 1988 CHEVROLET S-10
Electrical problem
1988 Chevy S-10 6 cyl 102869 miles
can someone tell me where the oil sending unit is located on my 88 S-10 4X4 pickup with a 2.8 engine?
MATT4401
  • 12 POSTS
It`s a 2 wheel drive truck
BLUELIGHTNIN6
  • 16,542 POSTS
The oil pressure sending unit/switch is located at the oil filter flange for the 2.8L engines.
Thanks for using 2CarPros. Com!
