Do an injector ohms test, compare all readings. You could move the number three injector to another cylinder, see if the code follows the injector.
Just about anything can cause a misfire, fuel--spark--vacuum leak, a lot of causes.
SPONSORED LINKS
Thursday, July 16th, 2009 AT 2:04 PM
