Do you have a check engine light On or has flashed?
Last major tune-up and what was replaced and adjusted?
When it refuses to start-try spraying carb cleaner in the throttle body-if it fires up and constantly running while you feeding it -you have a fuel problem-if it doesn't its an ignition problem.
SPONSORED LINKS
Wednesday, January 30th, 2008 AT 4:12 PM
