2000 Chevy S-10 my truck wont start
ROBERT29
  • 2000 CHEVROLET S-10
  • 4 CYL
  • 196,000 MILES
My truck wont start but the motor will turn over I have all ready replaced the crank sensor, spark plugs and I have had the coil packs, ignition control modual checked they are good its getting fuel what could be the problem?
Friday, May 16th, 2008 AT 5:32 PM
Its getting fuel what could be the problem?
But is it the correct fuel pressure? Hook up a fuel pressure gauge and give me pressure readings-if its on specs-your right back to the ignition system
replaced the crank sensor, spark plugs and I have had the coil packs, ignition control modual. After the replacement did you do a spark test?
Friday, May 16th, 2008 AT 6:46 PM
