Have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should get 12 volts. If you do, the starter is most likely bad. If not, check the starter relay under the hood in the power distribution box.
SPONSORED LINKS
Saturday, April 18th, 2020 AT 11:37 AM
