HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Symptoms
Overheat
1998 Chevy S-10 overheating
GARYHARRIS48048
MEMBER
1998 CHEVROLET S-10
1998 Chevy S-10 6 cyl Four Wheel Drive Automatic
how find out if fan needs replacing
Monday, July 5th, 2010 AT 10:24 AM
MECHANIC
What fan are we talking about? If its the clutch fan -when the engine is cold it should spin freely when hot will not spin easily
Electric fan motor-power it from the battery should come on
SPONSORED LINKS
Monday, July 5th, 2010 AT 1:20 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
2001 Chevy S-10 Intermitant Overheating
The Truck Had A Cracked Radiator So I Replaced It. It Never Got Hot Before (until The Water Was Low). Since Replacing The Radiator...
Asked by
1931chevy
2001
CHEVROLET S-10
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1994 Chevy S-10 Engine Overheating
During The Summer, Driving Uphills The Truck Tends To Overheat. With A Very Light Load ( 1 Sheet Of Plywood), Going Uphill, Tempature...
Asked by
coachjamo
1 ANSWER
1994
CHEVROLET S-10
2000 Chevy S-10 Overheating Has Air Cond.
Overheats On Hot Summer Days. Runs Great On Colder Days.85 And Below. Changed Water Pump, Fan Clutch, Flushed Engine@rad. Radiator 2 Yr. Old...
Asked by
john knott
2000
CHEVROLET S-10
1997 Chevy S-10 Overheated Engine
Engine Overheated, Makes Knocking Sound. Removed Inner Radiator To Remove Water Pump And Fan. Water Pump Seal Failed. Oil Is Slightly Muddy...
Asked by
buckshot88
1997
CHEVROLET S-10
2002 Chevy S-10 Multiple Problems + Overheating
Multiple Problems With My S10: 1. Typically My Temp Gauge Is In Middle At 210. Lately I've Seen It Run Up To 3/4 (240?) And Beyond....
Asked by
perkinsfmly
2002
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
