HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Fuel System
Fuel Pump
Replace/Remove
1998 Chevy S-10 Not crankin
JASONO12
MEMBER
1998 CHEVROLET S-10
4 CYL
2WD
AUTOMATIC
92,000 MILES
I changed the fuel pump and now my truck wont crank at all
Saturday, January 17th, 2009 AT 7:42 AM
JDL
MECHANIC
Hi, I'm not sure what your saying. When you say the vehicle won't crank, your talking the starter circuit, the starter cranks the engine.
Are you saying, it cranks good but won't start?
SPONSORED LINKS
Saturday, January 17th, 2009 AT 10:03 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1998 Chevy S-10 Changing Out The Fuel Pump.
I Have Been Told That Instead Of Dropping The Gas Tank, You Can Cut A Large Piece Of The Bed Out Over The Fuel Pump And Access It This Way...
Asked by
jbrssr
1998
CHEVROLET S-10
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
1998 Chevy S-10 Fuel Pump Removal
Fuel Pump In My Truck Is Very Noisey. Came On All Of A Sudden. Is It Advisable To Change The Pump By Myself Or Take It To A Place With A...
Asked by
davewood
1998
CHEVROLET S-10
98 Chevy S10 4.3
Replaced Ingnition Switch And Tumbler And Now I Have No Power To Fuel Pump
Asked by
lzrdkng27
2 IMAGES
1998
CHEVROLET S-10
98 Chevy S10 Truck V6
Would Like To Know What Would Cause This Truck To Stop Running, It Will Run For A Short Period Of Time And Then Die. You Let It Set For A...
Asked by
tonebug2003
1 ANSWER
1 IMAGE
1998
CHEVROLET S-10
1998 Chevy S-10 Died In Street,possible Fuel?
Engine Performance Problem 1998 Chevy S-10 6 Cyl Four Wheel Drive Automatic Just Got 4.3 Out Of Shop;had New Egr, Plugs, Fuel Pump...
Asked by
uncle stick
1 ANSWER
1998
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
Engine Not Starting
How to fix an engine that wont start
Fuel Pump Pressure Test
Online car repair manuals
