1998 Chevy S-10 Changing out the fuel pump.
JBRSSR
  • 1998 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 140,000 MILES
I have been told that instead of dropping the gas tank, you can cut a large piece of the bed out over the fuel pump and access it this way. Have you heard of anyone doing this? Were they successful without damaging anything under the bed?
Thanks,
Jim R.
Monday, January 26th, 2009 AT 5:35 PM
MASTERTECHTIM
  • 4,750 POSTS
Never heard of that method and dont recommend it. Removing the driveshaft will give you all the room you will need to access tank and thats what I suggest. *Be careful there is a vacuum hose at forward end of tank that needs to be removed when lowering tank. Sometimes I forget and break the plastic fitting in the tank, but they are replaceable if you do break it
Monday, January 26th, 2009 AT 7:18 PM
JBRSSR
Why would you not recommend it? My friend has a Chevy Avalanche and he pulled the back seat out, pulled back the carpet and cut a hole. Wouldn't it be simpler with a truck bed?
Thanks
Tuesday, January 27th, 2009 AT 12:51 PM
MASTERTECHTIM
  • 4,750 POSTS
I think inhe long run you will deystroy the bed and spend just as much time as if you did it the right way
Tuesday, January 27th, 2009 AT 5:25 PM
ISHEE77
  • 20 POSTS
I've only taken about an hour to an hour and a half to replace the fuel pump by dropping the tank. You can cut a hole if you prefer, just be careful not to damage the connections, tank, or lock ring.
Friday, January 30th, 2009 AT 1:12 AM
MASTERTECHTIM
  • 4,750 POSTS
We will gladly give you your money back. We are not hack mechanics and we dont promote being a hack. Removing the fuel tank will take less than a hour and you would not have had to cut a hole in your truck. I will make sure your money is refunded.
Friday, January 30th, 2009 AT 11:33 AM
MASTERTECHTIM
  • 4,750 POSTS
Just out of curiosity, what did you use to cut the hole in the bed?
Friday, January 30th, 2009 AT 6:09 PM
JBRSSR
Jigsaw, then cleaned it up, installed high voltage tape around the edges. Hinged one side and supported the other three. I'm in Construction, and have my techniques also. Maybe, I should ask you for a donation? Just kidding. It really does work well. If you go online and look at all the people who own Avilanche's who have pulled out their back seats, cut theses holes, you would be amazed at how many. It takes nothing away from the appearance.I have carpet in my bed with a cover. You just have to be careful when cutting. Some of the lines are within a couple of inches. Really. It's a grreat idea. These auto are known for fuel pump problems.
Hope this helps with any other onlookers!
Friday, January 30th, 2009 AT 7:25 PM
ISHEE77
  • 20 POSTS
Well, I know that I've changed countless amounts of in-tank fuel pumps, and after the first four or five times I've taken the time down to about an hour to an hour and a half. I time each job I do so I charge correctly and don't overcharge by rounding up the minutes or something like that. I'm not a full-on pro, and I do it at home as well. Oh well.
Friday, January 30th, 2009 AT 10:01 PM
