1998 Chevy S-10 fuel pump
JRSAINT
  • 1998 CHEVROLET S-10
Engine Performance problem
1998 Chevy S-10 4 cyl Two Wheel Drive Manual
I have a 98 chevy s10 pickup, 4 cyl. It had the typical bad fuel pump symptoms. I checked the relay (OK) and replaced the pump (not OK). Its not coming on when I turn the key (no buzz). What else do I check?
Tuesday, February 17th, 2009 AT 3:55 PM
Fuel pump fuse okay-if so check the computer fuel pump relay control circuit-might not be energizing the relay.
Tuesday, February 17th, 2009 AT 4:05 PM
JDL
  • 16,098 POSTS
Hello, you might check the ecmB fuse, plus that fuse circuit should be hot all the time. It should be located in the underhood electrical center.
The fuel pump relay supplies voltage to the pump and injectors both.
Tuesday, February 17th, 2009 AT 4:08 PM
