then die and not restart until I let it sit for awhile. When it dies there is no fuel presurre at the fuel test port and I can not here the fuel pump running when the ignition is turned on, all it does is crank. There are no dtc's either. Do I just have a bad pump? Or is there another problem?
Monday, June 7th, 2010 AT 10:51 AM
