1998 Chevy S-10 Compressor clutch blows fuse
1998 CHEVROLET S-10
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARIE NELSON
Engine 2200
I replaced the fuse to the Air compressor clutch, clutch started the compressor. I added small amout of freon to the system. The air conditioning blew cold air air in the cab, Job done, right. Not so fast. Drove the vehicle and the fuse blows on the clutch curcuit. Engine RPM more than just idle.
System pressure about 40psi.
Bad coil in the clutch?
How to remove clutch from compressor?
3pc. Delco clutch. coil is separate pc.
Bad compressor?
Jun 22, 2010 at 11:59 AM
SATURNTECH9
  • 30,869 POSTS
If the fuse blew the second you turn the a/c on?You could unplug the compressor and see if the fuse still blew with it unplugged.
Jun 22, 2010 at 12:02 PM
MARIE NELSON
The clutch works fine and the air conditioner functions at idle.
Put the vehicle in drive, raise the RPMs and the fuse blows
Jun 22, 2010 at 12:44 PM
SATURNTECH9
  • 30,869 POSTS
Does the center of the a/c compressor turn freely?
Jun 22, 2010 at 1:22 PM
MARIE NELSON
I am able to turn the center with my finger tips. It feels smooth and consistant.
Jun 26, 2010 at 1:39 AM
SATURNTECH9
  • 30,869 POSTS
Go to a auto part's store and turn a new compressor for your truck so you can see what they feel like when you turn them by hand.
Jun 26, 2010 at 4:37 AM
