1995 Chevy S-10 compressor clutch does not engage
1995 CHEVROLET S-10
LYNNTOMFLY
  • 6 POSTS
Air Conditioning problem
1995 Chevy S-10 6 cyl Four Wheel Drive Manual
I replaced the accumulator and the compressor, and put in interdynamics coolant/oil while engine running w/AC on. AC clutch did not engage - pressure gauge reads 37 static or w/engine & AC on. Before installing the compressor, I checked the clutch for rotation like the directions said to do. Compressor clutch does not engage.
Jul 8, 2008 at 9:27 AM
DOCFIXIT
  • 18,828 POSTS
Go to accumulator take low pressure switch off jumper with paper clip. Does clutch engage ? If so add freon till you get 35 -38 on gague . Replace switch and it should operate normaly.
Let me know
Jul 8, 2008 at 9:39 AM
LYNNTOMFLY
  • 6 POSTS
Jumpered switch connector - clutch engaged! Thank you. Now to get a new switch next time I'm in the big town of Reno. I'll get back to you in a few days.
Many thanks!
Jul 8, 2008 at 10:22 AM
DOCFIXIT
  • 18,828 POSTS
You are welcome stay cool
Jul 9, 2008 at 12:03 AM
LYNNTOMFLY
  • 6 POSTS
Installed new pressure switch on accumulator (I had cracked the original by using gorilla force to tighten plastic connector!). Now held pressure, however I hadn't evacuated the system after installing compressor & accumulator. Mech evacuated system, put in new refrigerant, and it works just fine!
I thank you for the rapid response you had earlier given me.
Jul 18, 2008 at 1:53 AM
DOCFIXIT
  • 18,828 POSTS
Guess you made it to Reno
Very glad AC is working well call on us again if needed.
Jul 18, 2008 at 4:06 AM
