1998 Chevy S-10 Brake lights arn't working
164,000 MILES • 6 CYL • 4WD • AUTOMATIC
FLADMARK
My brake lights don't work. The hazards, turn signals, and parking lights work but don't light up when i press the brake pedal. The fuses are good, the bulbs are good, and i replace the brake light switch. Still nothing. Is it a problem with the wiring and so how would i go about fixing that?
Oct 21, 2009 at 5:14 AM
CRZYDRVR
  • 432 POSTS
Did you adjust the brake light switch when installing? Check for power getting back to the rear brake light bulb. Maybe a pinched wire along the line. If all else fails replace the bulb with the correct part #. If the wrong one is put in, it may not be the dual filiament that is required.
Oct 21, 2009 at 12:51 PM
