brake lights stay on
MSTAMOUR
chevy s10, 2000, 58,000 miles and I do believe a 4.3 engine. Rear brake lights are staying on. The third brake light on top of cab operates correctly. Replaced the switch under the dash. Same problem. But when I replaced the switch, and unpluged the wires from the switch, the lights still stayed on! I found that to be very strange!
Any ideas?
May 6, 2007 at 4:34 AM
MSTAMOUR
Well I found out the problem!!
For a total of $442.00 including tax, the solution to the problem is take the steering column apart and replace the "multi-functional hazard switch" and then put it all back together again. Problem solved.
This is my "small donation" to this site. I hope this information will help others alot!
Thanks for your help.
May 7, 2007 at 10:25 AM
