1997 Chevy S-10 Brake lights
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOECASARES
The problem started when the blinkers went out once that happened the brake lights went next. Was told to replace brake switch and did that but fuse still blows when I replace. Then was told to replace blinker switch which have done as well still shorts out brake light fuse. When the car is on and the lights are on the brake lights are lit. I know it is probably a short somewhere but is this a known problem with this vehicle? and where can I go from here? Thank you,
Nov 4, 2008 at 11:20 PM
MASTERTECHTIM
  • 4,750 POSTS
is there a trailer light harness? if so remove it and see if short goes away. remove rear tail lights and inspect wiring at rear lights and inspect sockets where bulbs go for shorts
Nov 4, 2008 at 11:22 PM
JOECASARES
No trailer light harness and also checked brakelights they seem to be fine. When inspecting sockets is there anything paticular I should be looking for? any other suggestions or questions?
Nov 5, 2008 at 1:12 AM
MASTERTECHTIM
  • 4,750 POSTS
look for melt spots or rust
Nov 5, 2008 at 3:15 AM
