1997 Chevy S-10 6 cyl Front Wheel Drive Manual 182k miles
WHEN COLD, IT IS VERY SLOW TO FIRE. AFTER IT IS WARM, IT FIRES INSTANTLY. I HAVE HAD TO PUT STARTING FLUID IN THE THROTTLE ON SOME OCCASIONS TO GET GOING. FUEL FILTER OK. A LOCAL MECHANIC SAID A COUPLE OF YEARS AGO THAT THE FUEL PUMP MAY BE WEAK. IS IT POSSIBLE THAT THE FUEL PUMP IS FAILING, EVEN THOUGH IT STARTS AND RUNS
FINE WHEN WARMED UP?
SPONSORED LINKS
Friday, August 14th, 2009 AT 4:29 PM
