This could be bad spark plug wires/ spark plugs or even partially plugged injectors. You could also clean your throttle plate on both sides with choke cleaner. You could also have a vacuum leak, it would be better to have apro look at this.
SPONSORED LINKS
Friday, July 9th, 2010 AT 6:13 PM
