1995 Chevy S-10 oil pressure
ELMER UP
  • 1995 CHEVROLET S-10
  • 4 CYL
  • 211,111 MILES
I have a question. My oil pressure is fine when I start my truck. But after I drive it the oil pressure drops. To almost nothing. Then when I am idiling it goes into the orange and the check gauges light comes on.
Tuesday, March 17th, 2009 AT 7:38 PM
JAMES W.
  • 2,394 POSTS
Most common cause of the symptoms you describe is either worn engine bearings. With the high mileage you show, my first thought is; the motor is just plain getting tired. You can double check your dash gauge by removing the OP sending unit, and screwing a regular needle type liquid gauge in it's place but, you will find close to the same pressure reading. Hope this helps.
Tuesday, March 17th, 2009 AT 8:39 PM
