1996 S-10 2.2 FWD. The oil pressure drops down to very low or zero and I hear a rattle, as soon as I step on the gas it rises and the rattle goes away. I replaced the sending unit, Changed the OIL to a thicker grade, and replaced the pulley, What else could it be? If it is the pump I have to pull the engine. Which I have no money for. Is there anyway if I have to replace the pump or clean the screen, can I do this without completely dropping the pan? Will there be enough clearance to do this?
Help!
SPONSORED LINKS
Thursday, November 29th, 2007 AT 11:58 AM
