1994 Chevy S-10
TEARRAE
  • 1994 CHEVROLET S-10
Engine Performance problem
1994 Chevy S-10 6 cyl Two Wheel Drive Automatic
i got this truck with some problems but cant figure out what is wrong with it when it would start up it would run but it would run really rough when you put it into gear it would cut out and die. We replaced the plugs wires and spark plugs, and the fuel filter that is located under the truck on driver side between the wheels, we have also changes the air filter. It has now gottin to the point where it will not start it sounds like it isnt getting any fuel. To keep it running.
Saturday, July 10th, 2010 AT 1:49 PM
INTERNETMECHANIC
  • 700 POSTS
Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. Check for applicable trouble codes, you should be able to check mil codes, if there are any. A vacuum leak can cause issues?
Saturday, July 10th, 2010 AT 2:26 PM
