I am trying to set timing on my Chevy S-10, V-6, 4.3L, Vin Z. There are two grooves cut in the harmonic balancer (?) But I think we found the right one and whitened it. The tab with the timing degree scale is so rusted, that even a fine wire brush could not uncover the markings. Do you have a picture or explian how the marking would read? Also, is it normal for the timing marks to not line up after you are done and reconnect the tan wire?Black stripe under the glove box?
SPONSORED LINKS
Tuesday, December 30th, 2008 AT 4:11 PM
