1987 Chevy S-10 Timing way off and valves have issues!
AHRVKFAN29
  • 1987 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 190,000 MILES
My nephew has been driving my s-10 to and from work (a "quick oil change" company), and in his care the timing gear seal blew. Instead of waiting for assistance and the right tools, he tore into it and did half the work himself. Well, we're pretty sure that the timing got messed up, only we're not sure how far off. Can lay hands on a timing light, however I'm afraid to even run the engine at this point.
After the seal repair, for some reason there is terrible clatter coming from the lifters. Sounds like the rocker arms are trying to beat their way out of the hood! Never heard any noise like this from this motor before. After checking the oil, he assumed that the rocker arms were loose, and tightened them down to some torque that required a six foot, muscle- bound man to break loose. (We pulled off the valve cover, and checked to see if there was oil coming through, and it was observed that only 5 of the 8 rockers were even moving, and there isn't oil coming out of all the correct ports.)
Please tell me what we've done to this poor little trooper of an engine, and what we do first in order to get her back on her "feet!"
I don't know whether there's a problem with the valves, rockers, or head now; possibly even the crankshaft? And the timing, how do we tell exactly how far we're off without dismantling the engine again?
Saturday, August 9th, 2008 AT 6:25 PM
Sounds like you have a defective camshaft throwing the valve timing off- collapsed lifters/3 rocker arms not moving and no oil at valve train -the camshaft also drives the oil pump/distributor
Saturday, August 9th, 2008 AT 6:50 PM
AHRVKFAN29
And that could happen from something done during the repair of the front main seal/ timing seal? Didn't seem to be a problem before, but what are the symptoms of a cam being worn out?
Saturday, August 9th, 2008 AT 7:23 PM
MERLIN2021
  • 17,250 POSTS
To put a seal on the cam, the timing chain and gear was removed, so he might have not checked the timing marks. This is more likley the valvetrain problem, and the overtightening of the rockers. Symtom of a worn cam is backfiring thru the intake/carb. If this is what happened check for destroyed lifters and bent pushrods.
Saturday, August 9th, 2008 AT 7:49 PM
