1991 Chevy S-10 need help
STANGMAN233
  • 1991 CHEVROLET S-10
Engine Performance problem
1991 Chevy S-10 6 cyl Two Wheel Drive Automatic
replaced the head gaskets, intake manifold, rocker cover and distributor shaft gaskets, had everything running but had a code 34, map sensor too high, replaced sensor, thats when the car didn't want to start again. Put old sensor back in, still no start, rt- timed it, still no start. Got spark, got fuel, new tbi unit, new tune-up parts, etc. I have also cleaned 4 out of the six plugs, will do the other plugs tommorrow, need help please.
Sunday, July 13th, 2008 AT 10:01 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
How did you time it? Did you place the #1 cylinder at TDC and number 1 terminal to fire on the cap? Make sure it is TDC after the compression stroke and not after the exhaust stroke (180 degrees out of phase).
Sunday, July 13th, 2008 AT 10:30 PM
