Ok the other guy is right it doesent use a belt your vehicle uses a timing chain which connects the cam and crank shafts togethr to open and close the valves a the proper time.
It is located in the front of the motor you must take out the radiator, then remove the front of the engine parts will run maybe $60 but its a 2-4 hour job
Wednesday, January 27th, 2010 AT 10:21 AM
