1995 Chevrolet S-10 No Power
2CORVETTES350
i am working on a 1995 s10 with a 2.2 ,standard shift, 2 wheel drive, with 116 .000 miles .i have no power in it at all .with pedal to floor goes 3 miles a hour and make a racket of noises,i thought it was the timing belt but i checked it it fine ,i did a compresson check ,i have 120 on 1 st cylinder ,150 on rest ,figured i dropped a valve ,so pulled head no problem there ,any ideas i am puzzled
May 26, 2007 at 1:40 PM
  • 75,988 POSTS
[quote:706a0b2328="2corvettes350"]i am working on a 1995 s10 with a 2.2 ,standard shift, 2 wheel drive, with 116 .000 miles .i have no power in it at all .with pedal to floor goes 3 miles a hour and make a racket of noises,i thought it was the timing belt but i checked it it fine ,i did a compresson check ,i have 120 on 1 st cylinder ,150 on rest ,figured i dropped a valve ,so pulled head no problem there ,any ideas i am puzzled[/quote:706a0b2328]
Check for a clogged exhaust system
May 29, 2007 at 8:38 PM
2CORVETTES350
[quote:d8eabce499="rasmataz"][quote:d8eabce499="2corvettes350"]i am working on a 1995 s10 with a 2.2 ,standard shift, 2 wheel drive, with 116 .000 miles .i have no power in it at all .with pedal to floor goes 3 miles a hour and make a racket of noises,i thought it was the timing belt but i checked it it fine ,i did a compresson check ,i have 120 on 1 st cylinder ,150 on rest ,figured i dropped a valve ,so pulled head no problem there ,any ideas i am puzzled[/quote:d8eabce499]
Check for a clogged exhaust system[/quote:d8eabce499]
Oct 17, 2007 at 1:25 PM
2CORVETTES350
[quote:5091b20560="2corvettes350"][quote:5091b20560="rasmataz"][quote:5091b20560="2corvettes350"]i am working on a 1995 s10 with a 2.2 ,standard shift, 2 wheel drive, with 116 .000 miles .i have no power in it at all .with pedal to floor goes 3 miles a hour and make a racket of noises,i thought it was the timing belt but i checked it it fine ,i did a compresson check ,i have 120 on 1 st cylinder ,150 on rest ,figured i dropped a valve ,so pulled head no problem there ,any ideas i am puzzled[/quote:5091b20560]
Check for a clogged exhaust system[/quote:5091b20560][/quote:5091b20560]
Oct 17, 2007 at 1:27 PM
Suggested Repair
Check the exhaust system for a clog, such as a restricted catalytic converter or muffler, which can cause severe power loss and unusual noise.
Conversation Summary
The owner of a 1995 Chevrolet S-10 with a 2.2L engine reports almost no power, only about 3 mph with the pedal to the floor, plus loud noises. Timing was checked and found fine, compression was 120 psi on cylinder 1 and 150 psi on the others, and the head was removed with no dropped valve or other problem found. The expert recommended checking for a clogged exhaust system.
