1988 Chevy S-10 wont start
THOLDEN
  • 1988 CHEVROLET S-10
  • 6 CYL
  • 10,000 MILES
The tuck tried to start but it wont. Could it be because of the wather. I live in utah well vernal utah and it is always in my garage. We use th eather and I have changed the pluggs and wires and the coil. I even bought a new distributer cap. I just dont understand what is going on. Evey thing reads as ok but I just dont understand. Can you help?
tim
Wednesday, November 12th, 2008 AT 10:03 PM
Ether didn't work-I suspect an ignition problem-check ignition timing and test the distributor pick up coil.
Pull the coil wire from the distributor and ground it to the engine have helper crank her over-Do you have spark?
Thursday, November 13th, 2008 AT 3:52 AM
