Engine Mechanical problem
1984 Chevy S-10 V8 Two Wheel Drive Automatic
When I start my truck, it fires right up and can idle all day long, but when I try putting it into reverse or drive it dies, what would the problem be?
Monday, October 11th, 2010 AT 3:41 PM
JDL
MECHANIC
With the tranny in park or neutral there isn't much load on the engine. In drive there is load. How long since a tune-up? You may need to do a cylinder compression test? Any applicable mil codes? Use a gage and check fuel pressure.
