2000 Chevrolet Blazer Radiator Drain
CHEVROLET
JEFFZIMM
I am ready to replace the thermostat on my 2000 Blazer, mileage 102,000. I need to lower the antifreeze level in my radiator, but I can't seem to find a drain.
Where is a convenient drain plug on the radiator??
Thanks!
Dec 10, 2006 at 9:39 AM
GARFIELD
  • 197 POSTS
It is normally attached to the bottom corner of the radiator tanks, on some cars you have to take off the splash shield from under the front of the car to gain access to the drain petcock..
Dec 11, 2006 at 6:08 AM
DOVIER
You can find the drain at the left botton corner
of the radiator is right under the rubber hose. It is make out of plastic .
Dec 16, 2006 at 3:33 PM
Suggested Repair
Locate the plastic radiator drain petcock at the left bottom corner of the radiator, under the rubber hose. If it is hard to reach, remove the splash shield under the front of the vehicle for access.
Conversation Summary
The owner of a 2000 Chevrolet Blazer wanted to lower the coolant to replace the thermostat but could not find a radiator drain. Replies said the drain petcock is normally at a bottom corner of the radiator tank, specifically the left bottom corner under the rubber hose, and is plastic. Access may require removing the front splash shield.
