1994 Chevy 1500 Power Door Locks
CHEVROLET
LESS_THAN_CLUELESS
1994 Chevy 1500 Extended Cab/185,000 miles
A few months ago the power locks stopped working in my truck. What is strange is that the power windows still work fine. I have changed all the fuses without any success. Also, the passenger side button will unlock both doors, but will not lock them. The driver side will not do anything. Any suggestions?
Jun 13, 2006 at 1:59 PM
WILDTHING
  • 9 POSTS
hey i would start with switchs for both sides there priced decent and could just be that simple. If that dosent work you basically need manuals from the dealer and a mutimeter,testlight,and jumper wire to diagnose further.I just repaired my locks on a 94 camaro.good luck to you.
Jul 2, 2006 at 5:26 PM
MIKEYBDMAN
  • 623 POSTS
If the passengers side works it means the switch on the drivers door has gone bad but to be sure here is a guide to help you check for power and I have included the door lock wiring diagrams so you can see how the system works and which wires to test. Also check the ground under the left side of the instrument cluster.
Check out the images below. Please let us know what happens.
Jul 8, 2006 at 10:35 AM
Suggested Repair
Suspect the driver door lock switch, since the passenger switch still unlocks both doors. Confirm power and ground with a test light, using the door-lock wiring diagram, and check the ground under the left side of the instrument cluster.
Conversation Summary
A 1994 Chevy 1500 with 185,000 miles lost power door locks while the power windows still worked. Fuses were replaced without success. The passenger switch unlocks both doors but will not lock them, and the driver switch does nothing. Advice was to start with the door switches, then use a multimeter, test light, and jumper wire if needed. The expert said the driver switch is likely bad, recommended checking power and the lock wiring, and specifically checking the ground under the left side of the instrument cluster.
