1999 Chevrolet S-10 Emergency Brake Stuck
CHEVROLET
BETHANYSMITH
I have a 99 Chevrolet S-10 truck. It has 80,000 miles and is a 4 cylinder. When I try to set the emergency brake, it will not stay locked down. What could be the cause and the cost to fix it?
Jan 24, 2007 at 12:13 PM
SERVICE WRITER
  • 9,123 POSTS
?Without seeing it, I 'm not positive, but it may just be a matter of lubricating and working the dogs in the e-brake pedal assy.
Jan 24, 2007 at 12:59 PM
BETHANYSMITH
I was able to get it to lock down finally. Now the emergency brake release lever is not working so it's stuck with the brake locked down. What do you think?
Jan 24, 2007 at 11:59 PM
SERVICE WRITER
  • 9,123 POSTS
That's hard to say. It may be in the mechanism I mentioned above. It's tight to get in there, but you need to access the pedal assy. and get a good look at it. There are little levers or dogs that can get sticky and not want to move.
Jan 25, 2007 at 8:50 AM
Suggested Repair
Access the emergency-brake pedal assembly and inspect the small levers or dogs. Lubricate and work any sticky parts so the pedal can lock and the release lever can free the brake.
Conversation Summary
A 1999 Chevrolet S-10 owner reported that the emergency brake would not stay locked. After it finally locked, the release lever would not work and the brake remained applied. The expert suggested the sticky dogs or levers in the pedal assembly may be the cause and recommended accessing the assembly for inspection and lubrication.
