dex-cool coolant leak
CHEVROLET
HEAVNER
  • 6 POSTS
I have a 2002 Chevy Venture minivan with 52,000 miles. Recently it started to leak dex-cool coolant at night when the temperature drops down to around freezing. In the mornings, there is a small puddle of coolant on the garage floor near the center of the engine (slightly to the passenger side) of where the oil pan drain plug is located. To my knowledge the leak does not occur in the daytime or while the engine is running. It is hard to see where the leak is coming from but it appears to have dripped down the engine block from somewhere. It is not a the radiator hose. Please help!
Dec 10, 2006 at 2:51 PM
GARFIELD
  • 197 POSTS
You may want to give a good look at the intake manifold gaskets, I have replaced quite a few gaskets on new chevy's lately. Another common problem is the upper inlet plenum that cracks.
Dec 10, 2006 at 9:20 PM
