1996 Chevrolet Impala Crank No Start
CHEVROLET
96SSIMPALA
[b:92d403766d][color=darkred:92d403766d][/color:92d403766d][color=darkblue:92d403766d][/color:92d403766d]I have a 96 chevy impala and the water pump was leaking. and while driving the vehicle stalled on me. I have replaced the water pump. but now the car cranks but will not start. dont know what could be wrong with the car. [/b:92d403766d]
Dec 15, 2006 at 10:11 AM
BACKYARDMECHANIC
  • 337 POSTS
Check the wiring harness for the crank sensor. This harness is usually runs along the front of the motor and may have been disconnected during the repair. This will cause the ignition system to malfuncation and prevent the car from starting.
BYM :)
Dec 15, 2006 at 10:36 AM
Suggested Repair
Check the crankshaft position sensor wiring harness along the front of the engine. It may have been disconnected during the water pump repair, which can disable the ignition system and cause a crank-no-start.
Conversation Summary
The owner of a 1996 Chevrolet Impala replaced a leaking water pump after the car stalled while driving. The engine now cranks but will not start. The expert advises checking the crank sensor wiring harness that runs along the front of the engine, since it may have been disconnected during the repair and would prevent the ignition system from working.
