Chevy Impala Intermittent No Crank
YANKYANKUS
About every second to 10th time the car will not crank. New battery and everything else works. If I try to start it and it does nothing I put the key in the on position and the security light flashes. I have to keep turning the key to start position any where from 10 to 50 times before it will start, tha everything runs fine.
Jun 7, 2007 at 2:09 AM
SERVICE WRITER
  • 9,123 POSTS
Try using a different key, to see if the chip in the key is the problem.
Jun 7, 2007 at 1:25 PM
THUNTER137
  • 5 POSTS
2003 Impala 3.8L, LS, 45,000 miles
I turn the key and it won't start or click. Everything lights up. It has happens at least once a month for the last 6 months. Doesn't matter if the car is cold or hot. I will have to keep turning the key about 50 times to get it to start. After that it is fine. I can then turn it off and on. I took it to the chevy dealership and they said they could not find a problem. They said I will have to wait it out until it won't work at all instead of putting a lot of money into a problem no one is sure about
Jun 29, 2007 at 8:38 AM
Suggested Repair
Try a different key to see whether the chip in the key is causing the intermittent no-crank and flashing security light.
Conversation Summary
A 2001 Chevrolet Impala sometimes will not crank, while the security light flashes, and may start only after many key attempts. An expert suggested trying a different key to check the key chip. A similar intermittent no-crank complaint was reported on a 2003 Impala, but the dealer found no fault and advised waiting until it failed completely.
