Engine Mechanical problem
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic
My car was in high water. The starter was broke, so I replaced it. Now the starter turns but does not ingage the motor to turn over
Monday, August 4th, 2008 AT 7:50 AM
RHALL77
MECHANIC
Did you check and see if you have fuel pressure, spark. Is the security light blinking when you are not cranking the engine
SPONSORED LINKS
Tuesday, August 5th, 2008 AT 3:21 PM
RANDY1953
MEMBER
I believe having spark or fuel pressure has nothing to do with the starter turning over the motor. Again the starter does not turn over the motor, but does have power and turns but does not engage the motor
Wednesday, August 6th, 2008 AT 11:20 AM
RHALL77
MECHANIC
Is the engine (such as the belt and alternator) turning at all. If not, then you either need a starter or a flywheel. Remove the starter and look at the flywheel teeth and see if they are broken or not.
